Dde relay
I have a 2014 320d msport can someone please tell me where the dde relay is located?
Morning Garry
You should have an Engine compartment fuse/relay box up near a scuttle (probably hidden under a cover) R1 is normally the DME/DDE relay. I take it all fuses have been checked carefully also check the Main fuse box in the cabin fuses and Relays.
What leads you to think there is an issue with the relay?
