Remote services climtise don’t seem to get hot and the X3. Does not start remotely any ideas
Morning Stephen
Not sure what your asking here ? I was not aware your model had the function try using a BMW Vin decoder to get the original build sheet for your car that may help
Hi Dave , thx for replying, it all works heater blows and heater emblem appears flashing, however the heaters does not get hot the X1 I had did a great job , I know she has had a recall for starting motor and she does need a software update , would that cure it ? Thank you Steve
Hi Stephen
All fuses checked ? As you have had a recall best talk to them when your there Dealers normally run a Diagnostic check during a recall and advise of any updates needed
Good Luck getting it working hopefully with minimum cost 😁
