This is not just a re-calibration issue - I’ve tried that and it doesn’t work. A scan shows that there’s an issue with the Hall effect sensor in the motor that controls the forwards and backwards position on the driver’s seat. I assume that this is also why the memory function on the driver’s seat doesn’t work. The seat moves in all directions but the car just can’t identify where it is.
The motor sits in a bar under the seat. I’d sort of hoped that I could pick up a replacement but my local BMW dealer parts department inform me that it’s not available on it’s own, I need a complete electric seat base at over £700 plus VAT 😩
Has anyone ever encountered this issue before? Any advice or suggestions please? Is there any sort of workaround or is it feasible for the motor to be repaired? All help gratefully received.
Hi Glen
The best option would be an Internet search for a replacement seat one of our sons has a friend who has a 1 series early this year he brought a Complete interior Black Leather seats front and rear + trim and Door cards for £250 delivered. I would start with Realoem.com put the last 7 digits of your Vin into the search box it will bring up your model, then get the part number you need. Then contact the Register of BMW Dismantlers to see if they can help then Ebay
With luck it will be a straight seat swap at worst you will have to strip the seat to get to the motor you need.
Good Luck
Thanks for responding Dave. I have the part number and have started down the breakers route. Is the Register of BMW Dismantlers a thing? Could you point me in the right direction or send me a link please? I’ve Googled it but no obvious success.
Hi Glenn
I tend to use Quarry Motors they are very knowledgeable and helpful (also been around for years) try Googling BMW Breakers that may work
If not put the part number into an Ebay Search see if that brings results
Good Hunting
