Hi guys just got a BMW 330d but i keep reading the DPF & EGR could end up destroying engine turbo etc that will clog everything eventually ,i had a 320d before this one had no DPF had that car 10 years with np problems any ideas will be appreciated thanks in advance .
Hi Ali
I hear a lot of talk about DPF/EGR issues in my experience normally from folks who drive the car almost into the ground normally short journeys so service intervals are extended (if it gets one) and then complain about the DPF/EGR. The others who talk about DPF/EGR issues are often selling a service that will hollow out your DPF then with some software tweaks get it running without warning lights. They don't tell you that if an MOT inspector picks it up it is an instant fail
On the other hand my own X5 3.0d has just past 135k with no issues my brother inlaws 540d estate has just passed 200k with no issues (both cars had the EGR recall early this year) Brother inlaws car is Chipped and way over 400hp and driven hard (which these engines love)
So reliability for the DPF and EGR will depend on what sort of driving you do and regular annual service as a minimum (I change oil at 5k intervals), if you do a lot of local short journeys at least once a month give it a good run at Motorway speeds
Hi Dave thank you very much for your reply very appricciated yes i do beleive in lower mile services also i wonder if my bmw had a recall or not i tried taking EGR off to clean but was stuck am guessing very caked in soot hence stuck i took out swirl flaps not like idea them falling in to engine but must admit lost bit of power on bottom end not had it mapped yet thanks again Dave . Ali
Edited by BMW LOVER
I am in billericay essex who would you guys recomend to do a EGR delete & map my car also i use archoil injecyor cleaner i read ftom other drivers saying this cleans the DPF also any one else have any ecperiance with this stuff i been using it for many years great on keepinh injectors clean but not sure if it keeps DPF clean or helps it many thanks in advance Ali
Hi Ali
The emissions control system is kept clean by the action of the engine it's self. Two critical elements are filtered out Soot and Ash among many other particles, the soot is the one that clogs the EGR but is normally a sign of short journeys where the engine doesn't achieve full working temperature (note this is hotter than the heater starting to blow warm air) When full working temp is reached the car can measure soot content and if required begin a Regeneration cycle (note after around 2006 the engine management uses the Glo plugs to achieve regen temps, if they are not working no regen cycle) Once the regen is complete any resulting Ash is held in the DPF.
After 2006 the swirl flap design was improved and I have not heard of a fail or any falling into the engine
Considering the increase in the MOT and the likelihood of a fail if the examiner suspects any of the emission controls are tampered with or missing my personal preference is keep it as it was designed. My X5 3.0d 2009 has covered 135k and is as OEM build around town I get around 450 miles to a tank on Motorway trips closer to 600 miles to a tank. I change oil and filters at 5k with good quality BMW LLo4 compliant oil
The recent recall was for the EGR Cooler mine was tested and passed
Good luck with the hunt for someone to do the work in or near Billericay I am in sunny Sussex so not much local knowledge
Hi again Dave thank you very much for all the info you give me very appricciated i think i best buy a good scanner of some sort keep eye on things see if all glow plugs work & see how much soot is in the dpf my heaters work quickly but needle on dash takes ages to show normal temp but am guessing that could be the sensor what scanner do you recomend ? For this thanks again Dave
Hi Ali
Your car has an Auxiliary pump when the car is cold and the thermostat closed water circulates through the cylinder head (hottest first) the Aux pump pushes that water through the heater system to give a warm cabin. It can take 15/20 miles for the engine to reach full operating temp.
I use BMW ISTA/INPA which gives me Dealer level access plus it comes with WIS (Workshop Information system) and Wiring Diagrams so for me the best, today there are several on the market that are BMW capable iCarsoft, Foxwell plus a few subscription apps like Carly. Many will read fault codes and reset them but will not have service functions that allow Regen start (forced regen) DPF condition etc
Just make sure whatever you buy has the service functions
Thanks again Dave for all good info you keep giving me very kind of you ,you sure know your stuff Ali .
On 12/12/2025 at 8:49 PM, Greydog said:
Hi Ali
Excellent explanation. A lot of the anxiety about DPF and EGR concerns is greatly reduced by real-world instances such as yours. Frequent maintenance and safe driving practices have a significant impact. I appreciate you sharing your story.
