I would like to change the coolant on my X3 but have never seen hose clips of the type fitted as it looks like complete ring.  Any ideas on removal and tips on bleeding the system would be appreciated. Thanks
Morning Stewart
There is a drain plug in the bottom of the rad or simply pop off the bottom hose. The hoses have an "O" ring seal held by a spring clip, if you prize up the spring clip you can wiggle the hose off have a big tub/bowl to catch the coolant
