Cooling Fan removal
Cooling Fan removal
Its electric. Just shopping around to get one. Will let you know when its done. Thanks. That said this is Spain and everything is difficult to get. -
Loose/Worn Front Lower control arm th ball joint
Morning Kyle Welcome to the Forum If there is vibration at such a low speed I would suspect not only the control arm but is the wheel Tyre out of balance is the fixing bolt and ball joint torqued correctly ? Also consider if changing suspension parts it is good practice to change bothsides at the same time. The job is straight forward just make sure the main bolt is Torqued up when the control arm is in the loaded postion (Weight on the suspension) or the bush will only last a very short time. Dont know where you are but in the UK most suspension parts are available from Motor Parts Factors next day at least prce I would expect to be around £25 to £30 per side. Worth considering is a complete suspension refresh as if one control arm is that bad other parts will be worn as well Only you can assess the amount of risk as non of us can see/feel how loose things are Hope this helps Dave -
Cooling Fan removal
Morning Stewart Which model is it ? If the fan is Electric then normally they a quiet in operation if it is the engine driven fan then they are an easy change. Just remember the nut that holds it in place is Left Hand thread. Remove the fan shroud a good adjustable spanner just squeezes in on the nut, a whack with a rubber mallet normally loosens the nut the just wind it off. Now you have a choice, either replace it with a direct replacement or as I did with my 4.4 and 4.6 X5's I replaced it with an Electric fan from a later model (Fan and Shroud) activated using a Landrover top hose thermostat Dave -
5
Scraping sound under centre console on hard acceleration.
Great Result Kev Wonder what your Dealer would have charged 😂 Dave
