RHD right hand headlight
The solution is to also buy a starter motor from a G20 330e, the rest will fit without any problems. The cheapest solution is to buy a Sachs 2295 002 018 replacement dual-mass flywheel and then replace the starter motor with one from a G20 with the correct tooth spacing. The one from the F30 will not fit because it has a different number of teeth. -
Morning Paul There are a few others but these guys are very quick (72hr turnaround) in most cases used them several times for ABS units and a couple of times for ECU repairs big advantage with ECU's FRM etc no recoding needed I have also used Cartronix in Surrey but they were quite expensive and slow, end product was great though (upgraded Radio unit in an E53) Good Luck Dave -
Thanks Dave I think they are based in Heanor was looking at them yesterday but I will check your link all the same -
Hi Paul Just contact https://www.ecutesting.com they are in Derbyshire they offer and excellent service and I have used them several times they also Warranty all their work Worth contacting them and talking through what you need Dave- 1
Can anyone recommend somewhere for testing and fixing an ECU around the Warminster Trowbridge area please Don't mind posting if needed
