My  x3 2013 drives smoothly and has no warning lights or error messages. I have just driven from Manchester to southern Spain without any issues. When I plugged in my diagnostic tool it mentioned something about remaining miles. I have read somewhere that this was put into the software by BMW to appear at at set mileage of 120,000. Can anybody shed any light on this ? I have just added some cleaning fluid into the tank. Thanks
Hi Stewart
BMW of course deny any software jiggery pokery, however I have read of this before if you have the diagnostics can you read the Soot content and Ash content ? Th eSoot should be burnt off by the Regeneration cycle the Ash is what remains. One lad on another Forum had DPF warnings even though both Soot and Ash content were very low (single figure % ) he simply told his car it had a new DPF through the Diagnostic Software he had (his mileage was Starship stuff) no more issues
Thanks for that. Not sure if the Foxwell NT 520 has the option to check for soot and ash. I will have a look. Thanks again
Hi Dave,
It has the ability to regenerate and tell the ECU that a new Dpf has been fitted. I live in Spain and the diy car scene is non existent because a car has to be totally original to pass the mot to the point that I had to produce the original documents to confirm the electric tow bar was fitted at the factory.
Hi Stewart
I thought the Foxwell would be capable
If you have no warnings or faults showing i wouldn't be concerned as you can trigger a DPF Regeneration cycle whenever you wish (only really needed if all you are doing is lots of short journeys) my E70 I trigger around twice a year. No worry about the MOT and DPF as it will be the original, it's just the cars ECU that thinks it is new.
Hi Dave
Thanks for that. I am going to spend a bit more time on it just to get to the bottom of it all. I hve been quoted 420 Euros to remove and ultrasonically clean the dpf, but I am going to hold fire
