To runflat or not to runflat.
DPF Cleaning fluid
Morning Andrew Someone with the software can trigger a Regen if your isn't doing it it's self. For the regen cycle to trigger you need at least a half hour forty minutes with revs at 2500 or above you also need all the Glo plugs working as BMW use them to boost cylinder temps. Now the actual DPF, depending on DPF age and the type of journeys undertaken we are back to Software to measure the ASH content % as this is the bit that tells the car to show the warning and eventually go into limp mode. Solutions (1) take it for a good trash (Italian Tune Up) see if that works (2) Software there are several Diagnostic systems now capable but as I have INPA/ISTA that is my weapon of choice (3) Last is the Garage many will recommend NEW DPF ££ some will recommend DPF cleaning ££ (friend of our sons had this done seems to work) Both the last options will need software capable of resetting all the DPF adaptions to factory settings Dave -
DPF Cleaning fluid
Hi, I have a warning on my dash that the DPF unit needs attention. I assume this means it requires regeneration. Any pointers on best type of additive fluid to use for this and what is the most successful procedure, Thanks Paneuro. -
97' IL for sale
Going by that really enticing and highly detailed description, colour me not very interested. If you want to sell it as Reacher would say "details matter!" -
28
Gear box failure
Morning all, I'm a new member joining the group because I have read the issues in this thread and am also experiencing the same. Mine is. 220d 2 series active tourer from 2016. I also have play in the drive shaft on the near side and some oil around where the drive come out of the gear box. Mine is the aisin 8 speed. Has anyone collectively contacted BMW regarding this matter. I've heard BMW recalled this gearbox in New Zealand, so there is a precedent. -
Running Boards
Thanx for your response Dave I will follow up on your suggestions. Cheers.
