Hi Guys,
I’m after a bit of advice here!
I have changed the battery and now all of a sudden i’m getting the “Battery Restraint Malfunction” warning on the dashboard. When I go to clear the code and restart the engine the warning comes straight back on.
Any ideas what to check first?
Thanks in Advance.
Ali
Hi Ali
Have you checked that the battery holding clamp is in place ?
When the battery was changed was swapped like for like?
So update… clamp is in place, like for like and battery re-coded.
I have tried to clear the faults via obd and fault remains. 🤦‍♂️
Any other ideas??
Morning Ali
If all connections are in place and tight is the IBS cable connection good ?
Have you tried running live Data to see if you get any more information
      X3 2024 questions
    5. 3
    • medivd earned a badge
    • cubbykk earned a badge
    • Alan520d earned a badge
