X1 problems with connectivity and Carplay
I have a 2017 BMW X3 transmission fluid
I have a 2017 BMW X3 X Dr. 28 I what is a good alternate for automatic transmission fluid -
X2 coding issue rear indicator failed. Help!!
Hi James If you aren't aware take a look at www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model then look at Lights section. You should be able to see what you need and get an idea of how it goes together. If you need parts you will have the Part numbers then just Google them to get the best price It was the rear unit I wondered if the indicator was a Bulb (it is on the E70) Dave -
unable to figure why has crank no start 02' 330xi E46
Keys! have you tried a different key? does everything light up when you turn the key? when you switch the key to position 2, can you hear the fuel pump start to prime? (Whirling noise under the rear seat) the immobiliser will cut the fuel pump so if that doesn’t start to prime, then the immobiliser is the issue and the key/ reader is at fault. it happened to my x5. the fuel pump failed on my e46 too.. -
Hi Dave, thx for quick reply. Unfortunately IDK what a loom is or pins mean. However relays & fuses are all good. Wont be able to get diagnostic done, vehicle is no longer on the road, have insurance on it or runs. Another unfortunate thing is, the closest BMW dealership is 2 hours away and hard to find a garage that will work on a BMW in my surrounding area. I'm all for not getting parts don't need, but to be honest. That's what I did to get vehicle to run 1st time. I just replaced old part no matter if was needed or not. I didn't test any, just got new part. I don't and wouldn't know how to test parts. Making sure was same manufacturer and oem number. I tried this time around too, but I'm on here seeking advice. Thx again -
Morning Greydog, thanks for the warm welcome to the group! I do have diagnostic capabilities using Bimmerlink/Code with an OBD adapter. There was a fault present but looking into it it's showing as front right headlight issue and not rear! I'm going to take a look at fuses tomorrow however I know from looking into it there's not a fuse for the headlight itself rather the controller for the whole headlight system and a few other things. I'll also pull out the headlight itself see if there is a bulb, I'm sure they're LED though 😔 Thanks for the reply by the way, I'll keep you updated! James
