My 2007 530i bmw won’t start. Lights, windows, locks, dashboard etc are working, no sound at all when I turn the key. Same thing happened a few weeks ago. Tried my other key and it started.  I tried the key identification this time but would not start. HELP!!
Morning Sherry
To be sure you need a Diagnostic Scan as the issue could be anything from a failing Starter Motor to a failing Battery, an igition switch problem or Gerabox Inhibitor switch
Make sure the battery is fully charged (use the charge points under the bonnet) put the gear selector in N then try. Check all fuses and the Fuel Pump relay
The diagnostic scan would confirm what the issue is
