Bimmercode.
So,
Does anyone use Bimmercode, if so, what have you coded?
So far I've done: Video in motion, Cornering lights, adjusted NS Mirror tilt value, added Speedo in cluster, added Turn off Angel eyes in centre stack & others which I've forgotten.
Outer door handle lights in reverse has been coded but unfortunately doesnt work.
Morning Kevin
So your now our go to Guy for Bimmercode, not sure if I follow the door handle lights in reverse though !!
Personally never used it as I have BMW 1.4.0 (used for earlier iBus cars) and INPA/ISTA for all later models both programs allow full Dealer Level access for Diagnostic's and Programming
Using these programs I have retrofitted FCM and JBM.units Dealer said not possible 😆 On the E53's with a little additional wiring added Fold on Lock Unfold on Unlock Door Mirrors, DRL's (Neither function available on E53)
The main reason though is for diagnostic capability, keeping my cars and those of family friends and neighbours in good order
I'm only playing and reading up on stuffs myself, hardly a reputable source to offer advice!
So, mine has lighting package(?) so had white downlights in the outer door handles.  Allegedly, you can code them to come on when in reverse.  Currently only on when unlocking the car, or opening door and getting out.
Daughters 2015 Mini also has lighting package(?) & is coded, helpful when pitch dark so you can see along the sides when reversing.
