Fuel Pump Parts ID please
riber3
Hi everyone
I have just removed an E30 external fuel pump and I cannot id the attached parts (see photo) I think one is a regulator and the other is maybe a filter or accumulator? I checked the haynes manual and the on line parts page but I couldn't find a reference to them!! So any help would be welcome
Afternoon Paul
Take a look at www.realoem.com it is an online parts list as used by BMW Dealers
Either search manually or put your Vin number into the search box. It will bring up your model then search the relevant sections the small exploded drawings will help identify the parts and you will have the Part Number for ordering a replacement. Also if you double click the part number you will see a list of alternates if available plus any other models they were used on
Good luck
I used the RealOem site again using my vin and I still get the same result Part 14 listed as a an Absorber which doesn't sound right?
and Part 20 is listed as a hose? so any other suggestions would be welcome.
Here is the page n question
https://www.realoem.com/bmw/enUS/showparts?id=BA31-EUR-04-1986-E30-BMW-320i&diagId=16_0171
Morning Paul
Have you tried looking at other sites like www.pelicanparts.com check their "Articles" section they have some great how too's with pictures I am assuming that you are trying to repair/replace a problematic fuel system here.
In 1986 I was in a Sierra Cosworth so not in Beeemers, got my first BMW in 2002 a 4.4 X5. That was swapped for another X5 a 4.6is in 2004  However I would get part numbers then google them for Cost/Supply information so replacement can be done. The absorber may be there to take pulses out of the fuel delivery (only guessing here) BMW put it there for a reason and gave it a name they understood even if we don't 😁
Hi Dave,
Thanks for your reply and recommendation. I think I have tried Pelican Parts but I will try again just to be sure. My external pump is knackered and I do have a new one but I don't want to fit it until I know what the other parts do in case they need replacing as well.  I think you are right about the Absorber  and it makes sense even if we don't understand their terminology.  In 1986 I had a V8 Rover Vitesse but loved the cossies too!!!
Just found the absorber its called a damper similar to a fuel pressure regulator
https://www.pelicanparts.com/catalog/SuperCat/BE30/BMW_BE30_FULFUL_pg2_fuel-pressure-dampers.htm
BMW 3-Series E30 (1983-1991) - Fuel & Intake - Fuel System - Fuel Pressure Regulators
Haven't found the other part yet and its not in their listings
You will be our "Go To Man" to interpret BMW speak into English 🤣 I would be tempted to just source the lot hoses clips everything then you will know everything is right. Don't forget BMW have a Classic Section and are often helpful on prices for classics
My old Boss used to run V8 SD1's in the late 70's early 80's
      Folding mirrors
      Centre console iPhone charger
      Folding mirrors
    5. 3
    • Damion earned a badge
    • Stuiggy earned a badge
    • Penguin82 earned a badge
