Particle filter
Davison
What is the best way to correct this problem ,PARTICAL FILTER  warming message has came up on dashboard inside my 4 series grand coupe 2 litre petrol
Morning Kevin
Not seen this on a petrol model yet seen quite a few diesel though, as your car is only 4 years old unless it has covered more miles than the star ship Enterprise a blocked DPF/Cat is unlikely.
A diagnostic session should find the culprit quickly, my guess would be a sensor gone wrong. If you don't have your own diagnostics a good garage with a BMW capable system can do it. Or if you have an extended Warranty with BMW use them
The Differential Pressure sensor  sits on top of the DPF/Cat so should be fairly easy to reach
Hope this helps
10 minutes ago, Greydog said:
Morning Kevin
Hope this helps
      New Car New Questions
    • olly530i earned a badge
    • StuMc earned a badge
    • MikeDT earned a badge
