Fuel cut off switch ?
lucas
Hi I have a bmw 1 series 116d and the back end spun out on the motorway this morning causing me to smash in to the barrier the car cut out and won't start its not the cable on the battery that hasn't popped out just wondering if it had a fuel cut off switch dnd were I can locate it if it has . Thanks
Hi Lucas
I am not aware that the 116d had a cut off switch (I stand to be corrected as I haven't seen many) I would look elsewhere Furl Pump. Fuel pump relay Crank sensor, all fuses checked and OK. A Diagnostic session may be the wat forward
7 minutes ago, Greydog said:
Hi Lucas
Thanks dave ile get it to a garage and have it plugged in 👍
