Starting problems
Sparky2828
Hello guys
new to the forum but need advice. I have a BMW 320i 2007,,,went to start it but nothing,,,no light on instrument panel, nothing checked battery with meter says battery flat,,tried to jump start but nothing no instrument panel lights or anything is there a fuse that controls. this  I do not. Have a clue what’s wrong thanks
Hi John
I hope when you tried to jump start the car it was at the Charge Points under the bonnet ?? If you tried at the battery with it connected you can cause damage.
There is a fused link on the battery but I have never known one blow. Using a multi meter measure battery out put any thing below 10 or 11v indicates a dead or dying battery
My guess is a Dead battery
3 hours ago, Greydog said:
Hi John
Thanks Dave,,,yes I jumped it from terminals in engine,,,it started after a struggle ran for about 2 mins then died,,put metre on battery but totally discharged put leads back on but nothing no dash lights or anything
Then I would say your battery is dead the recent cold weather probably tipped it over the edge. New battery will probably sort it check that the battery is correct for the car and registered to ensure correct charging
      wheel fitment
      wheel fitment
    5. 8
    • Robbawdie earned a badge
    • hermit earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
    • jon green earned a badge
