Can’t get insta D to show fault codes
Tapping
Hi Daniel Welcome to the Forum Your tapping noise could be a number of things from a sticking hydraulic lifter to a failing chain tensioner. What is the service history ? Extended service intervals can cause issues get the Chain tensioner checked/changed would be a starting point Dave -
8
- contact failure
(and 2 more)
Tapping
Engine cut-out on idle.
I have a BMW 5 Auto Tourer Estate 2011. Tick-over very erratic - almost cutting out and sometimes does cut out whilst idling at traffic lights etc. Also I can hear a slight and constant hiss (not a whistle like a turbo fault). Any ideas what could be the problem. Many thanks.
