520D 2009 head light replacement to LED
Gary white
Morning Gary
First why the change ? What are you trying to achieve
I am pretty sure that your model year came with either Halogen or Xenon head lamps you could try upgrading the bulb/lamp. Dip will be Xenon main beam halogen so could be changed to LED as can DLR's also clean and polish the lens will help as they get stained and cloudy
The latest BMW headlights use LED for DLR and Laser technology for the Headlamps
As for sources first check if they fit and what is involved in controlling them you may have some wiring involved
Then specialist breakers/recyclers like Quarry Motors and search Google
Good Luck with the search
