Morning Paul
Never seen or heard of anyone using the App but from what I read all the App does is set the clutch in the transfer box to 0 torque.
You still have all the components, Transfer case, Front Diff, Front Driveshaft all turning plus the weight. If you have a transfer case problem it will still be there. So this old bloke doesn't see the point if you want rear drive I would trade the car.
      BMW X1 valve cover gasket replacement
      650i VANOS failure
      650i VANOS failure
    5. 2
      2017 430d LED headlight beam adjustment for continental.
    • GermB earned a badge
    • tomy987 earned a badge
    • Brummieboy77 earned a badge
    • Julian Pasiut went up a rank
    • tricz earned a badge
