mobile phone cable
Joseph80
I want to run a mobile lead from the central glove box adaptor along the driver's side, tucking the cable behind the plastic trim.
I have removed the dashboard storage box and central air vents, I am trying to get the cable from the drivers foot well up to the central storage box.
This is where I am stuck, does anyone know if I can run the cable without removing the radio, air con etc etc.
I can send photos if it is easier.
Many thanks,
Joseph
Photos:
1 - Car
2 - CAble plugged in to central consol by hand brake
3 - airvents and storage compartments removed
4 - Ran the cable along the plastric trim by drivers side wopuld like to feed it up to the dash.
5 & 6 - view from above to see if there is acces from the drivers footwell.
7 - Just shows where I would like the cable to come out
It all looks really tight space wise and may not be possible but thought I would try.
Morning Joseph
I use a section of bicycle brake cable outer which is easy to feed through tight spaces then tape the cable to it and pull it through, some times this has to be repeated in sections to get where you want to be.
As that looks like a charging lead, personally i would have taken a fused spur from a 5 amp fuse in the fuse box that may have been easier and a shorter route.
      wheel fitment
    2. 8
      Front windscreen washers
    4. 8
    5. 8
    • hermit earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
    • jon green earned a badge
    • Astonred went up a rank
