Alternator regulator.
Hi everyone.
I'm looking for a regulator Denso 104210-6070.
Problem is I stay in South Africa and for some reason they don't have that here. Or is there a reason for that? Otherwise I must replace the whole alternator. It's for a BMW 535i GT 2010
Morning Paul
BMW advise careful inspection of the alternator to determine the type and supplier meaning they used several suppliers ? not helpful
If you are not aware check www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model. If you double click the alternator part number it will give a list of alternate models it was used on that may help in sourcing parts.
Denso are common on Nissan, Toyota, Honda and Subaru so I would have thought that someone in SA would have rebuilt a few. Have you tried Denso Direct ? Or a replacement from a specialist Dismantler there are several in the UK. Another possibility could be a specialist repair company like ECU Testing or Cartronix (both UK) that rebuild stuff.
