F46 Media reboot (How to get to it?)
allexch
Hi Guys,
My Media is rebooting sometimes while I am driving, I think it might be cooler on the rear side of the box, because when I set temperature at 16 and max flow it looks like it's working fine. The problem is I can not find how to dismantle the front panel to get to the media, could someone share a guide/video or just explain how to get there, please.
Any feedback on problem itself  (CIC reboot) is also appreciated.
F46/2015.
Morning Aleksei
Try You tube for removal Videos they normally have something. To be sure you don't break or damage any of the trim parts get a set of Proper Trim removal tools they are not expensive and will prevent damage to trim and fixings.
The CIC fault could be a loose connector or a failing joint on a circuit board only stripping and testing will tell. Once out you can make the decision to repair or replace it.
  • Haha 1
      New Car New Questions
    • olly530i earned a badge
    • StuMc earned a badge
    • MikeDT earned a badge
