Central Locking
1989targa
Central locking only unlocked occasionally on N/S/F  door so had a techy fit a new actuator and it now works fine.
Took car home, tried to  lock the car and now O/S/F door will not lock!
Coincidence? Or some other reason?
Morning David
Bit freaky !! Does it lock using the key? As both actuators are the same age it could be it's failed as well or it may need lubrication or simply the plug connections cleaned with contact cleaner
