Stray vacuum pipe
Bruce
Hi Bruce
There is a transmission breather down there see if you can trace it back also check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model. Then look in the relevant section and see where the transmission breather is fitted.
1 hour ago, Greydog said:
Hi Bruce
Thank you
That's the one Bruce there should be tandem clips that fix it to the other pipes you should get some clues from the small drawings on realoem. The end is open to atmosphere I believe
