Battery
paulcyre
Morning Paul
Not sure what engine size you have but I would think a replacement around the 70 to 90ah range would be OK
Check www.realoem.com put the last 7 digits of your Vin into the search box, you will see your model called up then look in the relevant section for the information you need. The web site is a BMW online parts list same information that Dealers use.
As your car is shall we say "of an age" (bit like me) the battery wont require registering to the chassis so battery type shouldn't be an issue either. A healthy battery should show 12.8v measured at the charging points under the bonnet engine off, 14.5+v engine running
      04 525d
      2e47 & 2e41
      Coolant leak
      Coolant leak
    5. 2
      Coolant leak
    • Robbawdie earned a badge
    • Kev Miller earned a badge
    • Jeags earned a badge
    • olly530i earned a badge
