E46 Odometer display stays on
Chu
Hey guys so my 318ci odometer light stays on after I manually lock the car with the key (I believe the battery in the remote is dead) and the battery in the car was drained and I needed to jump start it. Anyone know what causes this to stay on? I also noticed that the middle interior light button also turns on the angels eyes previously fitted by the previous owner.
Morning Oliver
When the car was jump started I hope you used the under bonnet charge points and not direct to the battery ??
You could well be suffering from the efforts of a "Modder" who has done some weird things to find power?? You really need a Full Diagnostic read by some one with a BMW capable system. The symptoms you describe could be due to a failing or damaged LCM control unit, not unusual if the car was jump started direct at the battery.
