Condensation on underside of bonnet
Hi Members, I have a 2011 BMW 320i petrol, It has no sound deadening panel under the bonnet, the underside of bonnet is covered in condensation, is this normal please
Thanks
10 hours ago, Greydog said:
Morning Gary
It should have insulation under the Bonnet bare metal will suffer with temperature changes particularly as we move into cooler evenings which will cause condensation to form.
Thank you I will look for bonnet Insulation
Gary
Morning Gary
Check the BMW Specialist dismantlers like Quarry Motors they may help at a sensible cost plus there is always BMW but not cheap, don't forget mounting clips/screws
Take a look at www.realoem.com it's a BMW parts list put the last 7 digits of your Vin into the search box it will bring up your model then look in Bodywork it should list everything you need.
