Engine Failed with broken timing chain
Hi Paul Just contact https://www.ecutesting.com they are in Derbyshire they offer and excellent service and I have used them several times they also Warranty all their work Worth contacting them and talking through what you need Dave -
Can anyone recommend somewhere for testing and fixing an ECU around the Warminster Trowbridge area please Don't mind posting if needed -
E64 oil filter holder life
Finally, I did take it the damaged part into BMW but heard nothing........ -
Hi Dave, that is a possibility, over tightening, but I understand the material used does have weaknesses especially when it is cold. I was lucky, the day before Im doing 85 on the motorway, no issue, the next day on start up, part failed and luckily no heat got into the engine before I realised. Hence the question. But good to know there is no actual recommendation to change at intervals. Appreciate the research. -
5
My new E64 650i
Yes, in normal driving mode if you take you foot of the gas you will hear the engine changing down. When in Sport mode however that does not happen unless you are using the manual change down. Check out the video I referenced.
