bmw 116i running poorly :(
adamhorton1991
I have a bmw 1 series 116i 2012 plate with 91k on the clock ive notice lately there is a slight miss fire / jerking when driving when cold but there is no codes showing for this. also ive notice the fuel consumption is creeping up a little even when driving in eco mode it says im doing 33.5mpg but doesn't seem right to me or maybe im over thinking the mpg a little, I was using a lot of oil at one point but I changed the oil and put some in from bmw and its been alright since fingers crossed
any suggestions on what to check and were to start I have some knowledge of mechiancs but not in a great technical detail
many thanks ADAM
Welcome Adam
Check the in-let side for any vacuum leaks a perished or split hose can give the symptoms your seeing, then check all electrical connections unplug give a good squirt of electrical contact cleaner (not WD40) clear down the codes and see where it takes you.
      650i crank no start
      Parking Break Failure
      650i crank no start
      Suspension upgrade
      Suspension upgrade
