Fuel Pump and O2 Sensors
19
Thank you Greydog for your help! Yes, the Maxi unit reprogrammed the RDC but it does not correctly erase the old RDC coding data. That’s why it only work until I stopped the car. Now I know I need another tool to get the job done. 🙂 I will be waiting for your answer! Thanks! -
E90 Cigarette Lighter Fuse(s) Help
Hello all, I have a 2007 328i and the front cigarette lighter socket and ashtray light are not working. The socket in the center console arm rest does work. One fuse I've seen listed on forums is a 20 amp in position #30. On my car marked as 12v accessory. This fuse is not blown. I've seen some posts say fuse #8 is also the 12v accessory socket but on my car that is a 5 amp marked as CD Changer. Is there another fuse for the front 12V socket that anyone is aware of? -
19
Morning JC That's better information A neighbour has i-Carsoft if he is around later today I will have a look At least you now know the cause, will your Maxi unit allow registration ? Dave -
19
I used another ODB reader, I am able to get additional information about the error code. It looks like the used RDC is not properly reprogrammed to work with my car. Do you know if the I-Carsoft 3 or Foxwell 510 is able to reprogram the RDC properly and resolves the errors? Or if the BMW INPA/ISTA the only tool that can fix it? Thanks!
