Fault Codes
skyline
hi all new to the site i have the x5 30d 53 plate only had it a short while started having a few problems recently
so please bare with me as there are a few .
i had the turbo changed as the other failed but still getting black smoke on hard acceleration
keep having check brake lining on dash but all seem ok
also transfer fail safe on dash but this comes on then goes of at random
also just got it back from sytner bmw with a lot of fault codes if anyone could help me with
it would be very much apreciated
here goes
000002 RAD
000003 STH
00000B STH
00000D STH
000012 PDC
000016 PDC
000037 EGS
00007C LCM
00008D IKE
00008E LCM
000093 LCM
0000BD IKE
000100 DDE
001260 DDE
001613 DDE
001E30 DDE
003505 DDE
i know there are a lot me an wife getting very worried as we put our savings into this car we are begining to woner wether we made a big mistake your help would be very much aprecited
thanks
If you bought it from a garage then take it back and tell them to sort it, if you bought it private sale then oh dear. Start googling the fault codes. You must get the codes cleared then run it a few hundred miles and see which ones have come back, and as long as its black smoke under hard acceleration they all do it but not so as it blocks out the sun.
Steve
First I agree with Steve if you brought it from a Garage take it back and ask them to sort it.
However if you want to sort it or understand it yourself I will try and help with the codes,
000002 RAD This is a Radio code if the radio is working I would suspect a speaker fault somewhere not fatal to the car
000003 STH Auxillary Heating Control I don't have this again not fatal to the car
00000B STH As above
00000D STH As above
000012 PDC This is Park Distance Control probably one of the sensors in the bumper these are a Royal PITA on many X5's
000016 PDC As Above
000037 EGS Electronic Gearbox control this could be linked to one of the DDE faults but needs further investigation
00007C LCM Light Control Module if all exterior lamps light then it needs investigation suspect earth points maybe
00008D IKE This is Instrument cluster electronics could be anything from a duff earth to a bulb out not fatal to the car
00008E LCM As above
000093 LCM As above
0000BD IKE As above
000100 DDE These are all Diesel Engine Management related as I don't have a diesel I cant be much help
001260 DDE As above
001613 DDE As above
001E30 DDE As above
003505 DDE As above
You say you had the turbo changed, why? Again if the fault was there when you purchased it it should have been the responsibility of the selling garage.
Why did Synter have the car?
The turbo change could have triggered some of the engine fault codes and if there is an air leak contributing to them.
Sometimes the codes can be reset and wont return.
Hope this helps
Thanks for your help very much appreciated I brought the car
Private the reason for a turbo change was due to smoke &
Lack of power when the turbo came of it was shot must admit
I took the car to bmw because of transmission fail safe 5
Looks like I've got my work cut out with the car again thank you for your
Time looking into this
OK, X5's are very sensitive to voltage changes/ battery condition if they are low it will throw all sorts of spurious warnings. If you are looking to sort it yourself buy a BMW 1.4.0 scanner about £15 to £20 on ebay it will let you see whats going on and give fault codes in English. Next I would get the battery checked, if its good make sure its fully charged if not or unsure replace it with a good quality battery. Don't sit with ignition on and engine off for long as these can flatten a battery in no time due to the amount of current all the systems take.
Each control unit retains codes so some of the codes you have may have been there for some time, even BMW often just clear the codes then drive the car to see what comes back.
With the DDE codes I would check the MAF and clean it EGR clean or replace it. Thermostats are a known issue when running is your needle dead centre?
The Webasto Aux Heaters can be a problem but are not really going to effect the main car so this and the radio and lights would be down the list to fix.
thank you couldnt tell you how much i appreciate all the time and effort you have put into helping me
i have looked at the scanners the one i have found is
bmw scanner 1.4.0 diagnostic interface code reader scan tool E38 e39 E46 E53 E83 is this the one ime looking for
again thanks
That's the one. I have mine on an old laptop running windows XP that I just keep for garage use now. You can run it on later Windows but will need to set up a Virtual Machine.
Once you are up and running read the codes Note them then clear them. Run the car and see what comes back, then work through them methodically.
As said I would start with the engine codes
Good luck
thank you i have ordered this now will be here next week
done some work i have changed all pads & rear discs as they looked worn
also i removed the egr valve this was badly gunked up cleaned it with carb cleaner & brush
the car seems a bit more responsive at the moment will see how it goes
i will plug the reader in when it comes and let you know how it goes
again thankyou for your help very much apprecited
      650i crank no start
      650i crank no start
      Parking Break Failure
      650i crank no start
      Suspension upgrade
