New Member
Can someone please enlighten me on how the auto grill system is supposed to work? My 2018 M40i has this system fitted but I don't recall seeing it closed I understood that it closed during cold weather to allow the engine to warm up quicker. -
5
5
Hi Dave, Sure, realoem. Part number (steel gasket) is 11628576287. and according to the second drawing (please see attached), this is the EGR Line Gasket. Andrew -
5
Hi Andrew Are you using www.realoem.com ? The drawing looks like it or is that from the Internet? Is the turbo fitted OEM ? Dave -
5
Hi Dave, Thanks for your reply! Removing the turbo is not that challenging. The challenge is to find the right gasket.. And here I’m a bit helpless, since no.8 on the drawing does not fit there. Looks like there simply isn’t any gasket.. Andrew
