Rock Solid Brake Pedal
lingo
A quick google search threw up a few threads about possible vacuum (air) leaks causing stiff brake pedal and checking all of the lines may show up a fault. Might be worth a look. This can also result in a slight missfire of rough idle. Apparently.
The servo and master cylinder that were sent were wrong so no luck as yet. I too have read those threads hence the purchase of the relevant parts. I have no ruff idle though and the non return value on the vacuum hose is working. So I'm almost certain it's servo related
      New Car New Questions
    • olly530i earned a badge
    • StuMc earned a badge
    • MikeDT earned a badge
