Best Handsfree Bluetooth Solution
Power Message
Hello, How's the car been since then? Just had the same message pop up then smoke and loads of it, need to wait till Monday to get in contact with the BMW main dealer we purchased the car from which we have extended warranty with -
Folding mirrors
Morning Damion I would say yes to the software update (but a Dealer will charge £££) this should be in iDrive try My Vehicle, Vehicle Settings, Doors/Key, then scroll down to mirrors and check Fold Mirrors when Locked If that doesn't work you need help from someone with a BMW capable diagnostic package (ISTA/INPA) to check if it is in a hidden menu. Be aware BMW are making it harder and harder to tinker with the cars mainly after 2019 year so you should be OK Dave- 1
Centre console iPhone charger
Morning Rob His was in the car when he brought it and is OEM (car is BMW 330e 2019) apparently works well with his iPhone but not with our daughters Android phone. You could talk to your Dealer but make sure your wallet is in a protected spot 😁 as I have know idea of cost ££££. If BMW are fitting them then there will be Retro fit kits out there from the Far east so worth looking at the Auction sites but I have no knowledge of quality other than the screen in the X5 failed and I replaced it with a complete Android unit from Ebay at less than a 1/3rd of the BMW quote. Truly plug and play allows switching between the OEM CiC and Android gives better GPS and many other programs and has been totally reliable for the last 3 years (that's killed it ) Me I don't spend long enough in the car for my phone to need charging these days 😅 While the X5 has Android Auto and Carplay I have to say like a lot of gadgets they are rarely used. Bluetooth is the only thing I see as an essential Good Luck with the search for a solution Dave -
Folding mirrors
Dave, Thanks for coming back to me, would be really interested to see what he’s done 🙂 Thank you Rob
