Parrot Installation
mikesmith2939
I have just installed a Parrot MKi9200 into my E46.
The biggest problem I had was with the isot lead, because the wiring is quite short and the connector very large it would not feed down towards the glove box area.
I ended up having to take the centre air vent plus the air con control panel and the radio cage out.
Then I pushed the radio into the cage then whilst pushing the cage back in worked the connector block up and to the left to allow the whole thing to slide in.
Took a lot longer than I was expecting but it is now installed and working.
That's true, but you'll get a nagging 'cos you're ignoring calls. The question will be 'why did you waste the money on that thing, you don't even answer'
I've been there I know ha ha
