Just A Chat Up!!!!
What's the noise and what is the real issue
Lift the car up and see if the wheel moves freely when the handbrake is off. then its brake disc pads without copper grease. -
My immediate guess is the handbrake shoes are too tight. People forget they are in there, separate from the disk pads. how old are brakes? -
Hi, Can someone help me to identfy what is the noise coming from X3 and the real reason for this? Thanks VID-20250425-WA0000.mp4 -
9
Bumpy
Hi , sorry been in work all day. Front Both sides 225/45/R18 95y Rear Both. 255/40/R18. SPORTDRIVE -
9
Bumpy
But What size front are 225x?x? rear the same 255x?x? If wheels are 17" they should be 7.5J rims 18" 8.0J rims 19" should be 8.0J all round or if wider rears then 8j front and 9j rear The ONLY wheel set that has wider rear rims is 19" so if your car has 17" or 18" wheels the tyres are probably wrong just checking the width does not make them correct Dave
