Does anyone know if a blow off valve will fit straight on to a 118d m sport? Thanks
you need to get a universal dv only one make for the 118d i recommend forge or balley
1 kit available..
oh !Removed! nearly forgot
not recomended on any diesel plays hell with them!!
Ah really mate? In what way?
its not just a case of put it on job done!!
1=remap will be required
2=sometimes messes with fuel/air sensor
if you want to put one on just do it liam :) ebay for kit
It's been chipped, just wasn't sure if it was a straight forward as just putting one on. Thanks for your advice, think I'll ask revolution a place in Newcastle that sells them and see what they suggest. Thanks
i sure it'll be a easy job to fit it.. u'll just need a remap after :)
Ah money money money! Are stage 3 Motorsport blow off valves good? Got a friend selling one
i dont no about stage 3 DV's
i have this one for sale. if it will fit your motor i dont no!!
its off a 1.8 turbo audi engine
post-7423-0-89419400-1390502220_thumb.jp
Ah if I knew it was going to fit I would buy it mate, I'll do something investigating at work tomorrow ha! Do you know the model etc? Just to ask about, thanks
Purpose of a blow of valve:
Reduces pressure returning to the turbo when the butterfly valve from the throttle body is shut when you release your foot from the accelerator pedal.
Petrol engines: Fantastic. Works great because you HAVE a butterfly valve to control the engines power
Diesel engines: Pointless. Does not work because diesel engines DO NOT have a butterfly valve controlling the engines power. Pressure from the turbo is directed straight into the intake manifold and used by the cylinders ingesting it as it needs it.
To answer your question: You can't
Hope this helps
Daz
Ah thanks daz, peace of mind now ha cheers
