Restraint System
Morning Andrew Welcome to the Forum Unfortunately the only solution is to strip it all down and then find it is a £0.50p gasket (hopefully) Good Luck Dave -
DPF Cleaning fluid
DPF Cleaning fluid
Thanks guys, I'm going to give it the beans a bit tomorrow and see how that goes. I'm trying to get into the secret menu just to get an idea if it does a regeneration while I'm driving it hard. I will let you know how it goes. Thanks Paneuro.
