Newbie From Shropshire
DPF Cleaning fluid
Morning Vionea Welcome to the Forum Not sure if you want to replace what you have or make your own ?? Brand new from BMW in primer these only cost around £10 each or if you get the part number from www.realoem.com then search the Internet I dare say there are more than a few out there Good Luck Dave
