E36 318Is New Brakes
Hi Everyone,
I finally got my new brakes all fitted. I have replaced front pads, disc's and sensor. Rear pads, disc's, sensor and handbrake shoes. I ran the them in for about 180-200 miles keeping off the heavy braking or driving to fast :P. But now when under gentle braking I have squeaky brakes.
Could this be due to being new brakes and the're just getting bedded in? I copper slipped everything that should be and cleaned up the carriers so shouldn't be that.
Or could it possibly be a seized/sticky calliper? I didn't have a bit of trouble pushing back the front drivers side but all the rest were fine.
Cheers boys and girls.
Steve.
Did you "score" the pad surfaces? Did you get rid of all the old brake dust and rust?
Try copper-greasing all the bits n bobs (including the springs etc but not the pad linings lol)...
Yeh, scored all the pad and shoe surfaces. All brake dust and rust cleared as much as possible. The only thing I didn't copper grease are the springs for the handbrake shoes. Don't see that causing the squeak under light braking though. Copper greased the back and edges of the pads and the carriers.
I'm leaning more to a possible seized calliper :(. Had a bit of trouble winding back one of the and the rest pushed back quite easily.
Yeah, a seized caliper could cause it but wouldn't the wheel be warmer than the rest?
Hmmmmm this is true. I'll check tonight when I go out. Cheers mate.
