E24 Wont Hold Charge
dodgym3
Hi Guys
I have a 1989 635CSI that will not hold charge..
I have replaced the battery and altenator but when i drive lights start to go dim then when i stop it wont start as no charge.
Any ideas/common faults?
Thanks
Tim
First job (easiest) is to check and tighten ALL the earth-leads/straps... Often this will cure it.
Next job, run the engine and test the voltages with a meter (anywhere theres a positive), test on a few different locations to eliminate broken connections.
Finally, if no solution so far, check relays and regulator for operation/connections... Go back to second job !
Just a simple method HTH
    2. 12
    3. 12
    4. 12
    5. 5
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
