Hot Rod Diner Meet Comming Soon !!!!
Good to know Dave, Thanks! If I can't use them on the fob I'll put em on something. Here Kitty Kitty:) -
2e47 & 2e41
Hi Joe If memory serves 2e41 is bad communication between the EWS and DDE the other 2e47 is Thermostat or Sensor related. Looks like that sorts your weekend Dave -
2e47 & 2e41
Sorry of mentioned before, started car this morning and was fluctuating a little on idle. Completely fine after a few mins. Though I'd scan the car anyway and found errors 2e47 and 2e41 stored. They are intermittent and once cleared, don't come back for a while but I thought I'd check in case it was something to worry about? E87 118d N47 Cheers, Joe -
5
E87 Whine on acceleration
Been a while, forgot to update sorry. Turned out to be the belt tensioner pulley at fault, bearing was goosed. Hope this helps some people. -
5
Thanks for the update Rory hopefully your experience will be good. I spoke again with the Merc/Porsche specialist I know apparently the tags he has seen are both Apple and in use by Porsche owners Dave- 1
