2003 3.0D Auto X5 Cranking But No Starting
AndycX5
Hi,
Just wondering if someone could give me some pointers on what might be up with my 2003 3.0d automatic X5, The other day I was driving up a steep hill as I pressed the accelerator down there was no change in power and the car struggled to get to the top, I drove about 400 yards to my girlfriends house at the end of the road with the car not accelerating no matter how hard I pushed down on the pedal. I left the car outside returning to it about 2 hours later to find when I turned the key it was cranking but not firing up. The car had to be recovered to my house where it still wont start, any ideas on what may be the problem???
Thank's Andy
Any other symptoms like black-smoke or misfire? How much fuel in tank?
How are the other fluid levels/condition? Did it overheat?
There was no black smoke or misfire it just went really slugish as if there was no diesel coming through as i pressed the accelerator, i had put 20 litres of diesel in the day before this happened and the range was at 176 miles, the car has just had a full service last month and the levels appear to be fine, it did'nt overheat and no warning lights came up on the dash.
Do me a favour, disconnect the battery earth-lead overnight... Reconnect and try in the morning, i'll have a hunt in TIS for a solution ;)
So far people has said it will be, 1: diesel pump 2: fuel relay 3: battery. I don't see how it could be the battery as it was cranking when i was turning the key and all the electrics worked but i was told to check it anyway
If it was any of the above then you will have Fault-Codes... Maybe the fuel pressure regulator at worst!
Because it will rev to 2k the pump should be fine (famous last words)...
Apologies... Thought it may clear some "Mickey-Mouse" codes.
There is NO recall on the 3.0d X5, is yours the M57 or M57TU?
Try leaving the ignition on for at least 1 minute, this method tries to purge air from the post fuel heater...
(Have you done ANYTHING since it was ok?)
Still dragging thru TIS as we speak !
As above..
Taking battery off on modern cars will don nowt except rest your clock etc.
you really need to get it code read.
It sounds like it went into limp mode for some reason..
Sorry Jack been out for the day, it is the 181hp m57 and the only thing i had done a couple of day's prior was fit 'error free' xenon white sidelight bulbs. I was told it could'nt be that but i put them back to standard just incase it was them
      wheel fitment
      wheel fitment
    5. 2
      wheel fitment
    • hermit earned a badge
    • Robbawdie earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
