E63 635d Auto - Transmission service.
Hi Dave. Thank you for your quick reply. SCARY is the first thing that comes to mind especially as I can no longer do my own work on my cars unless it is something like changing wiper blades and stuff that does not require a garage for shelter in the event of bad weather ! I will sound-out my Indy as I have been using him on my previous 4No E45's. A very very brief word with him a little after opening up your post revealed that the transmission service on the forthcoming E63 involves a new sump (made of plastic !!!) which has an integral filter as part of the construction. He was talking a figure circa £450.00. We will see when the time comes. -
Locked out of a 1990 525i
OK can you not raise the car and through the engine bay pull the bonnet release cable, once you have access to the engine bay you should be able to change the battery and power the door locks The only car I have had real problems with had no battery fitted at all Good Luck -
INPA / ISTA / Coding help - How and what to get?
Morning Mobeen Copies of INPA/ISTA are mainly pirate so not knowingly sold by members So you will need to search the internet if buying I would make sure the Software and Cable are together also be aware that some versions will not work on a 64bit system (mine runs on an old Windows 7 32bit system) Good Luck Dave -
Hey BMW and Windows 2024 X1
Morning Alan I would think if it is possible it needs activation in the Operating system However I have to ask "Why" all my BMW's have had voice activation to some degree but I have never used it I tried on the early X5 then it was Radio and Phone only and to say the least it was not good !! A request like "phone home" would be answered with something unrelated like Radio 4 selected 🤣 So I have never bothered since all the buttons work and so do my fingers 😅😂 Dave -
Morning John Not just the marques you name the poor old gearbox and Diffs are probably the most abused parts of any car. With most Garages Oil and Filters and a quick visual inspection is seen as a service (time is money) ZF Service intervals are 60k to 100k Kilometres (about 60k miles) So "sealed for life" for most Marques meant "End of Warranty Responsibility" My X5 E53 4.6is was serviced by ZF the cost was £630 (8 years ago) but they pulled the Mechatronic unit serviced it and fitted new seals flushed the Torque converter the put it all back. Even though my box was smooth it felt better after service. My X5 E70 I have doe myself using genuine ZF parts cost was £220 Fluid Filter Sump Seal and Bolts (Euro Car Parts last year) I also changed fluid in both Diffs and Transfer Case Check Google for ZF specialists or a ZF service centre for costs if your not into DIY Dave Tip make sure you can undo the fill plug before draining the fluid I had to help a friend who had drained his box then couldn't undo the Fill plug and damaged it
