What The Widest Wheels You Could Fit To 530D Tourer Sticking Out
Knocking noise top of engine.
Morning Ross I would start by checking that all injectors are OK, seated properly and fixed down at the correct torque. If there are no injector or glow plug issues then the valve train needs investigation could be a lifter sticking or a Vanos issue. Dave -
No Sound!
I have exactly the same problem BMW say it is due water getting ito the amplifier which needs replacing £1800 The problem is it looks like a designe fault which they wont admit to, so it will happen to the new amp -
Hi, I have this knocking noise on the top of the engine. It started with a low knocking sound then it got progressively worse until I stopped and got recovered. New top turbo 3k miles ago and fresh oil change. Car seems to be all working fine apart from the aggressive knocking. Any ideas? 2013 x5 40d 110k on the clock. IMG_6024.mov -
7
Loud knocking noise front top end and smoke
Hi, I have the same fault, was it the injectors?
