Wheel Fitment
dazza67
I currently have fronts et 20 rears et 32.
Wheels 18 x 8 front 18 x 9 rears.
There is plenty of room between suspension and wheel, but I'm lowered -100mm front and -85mm rear and I get arch rub even with stretched tyres under heavy cornering.
But if your not going silly low, you should be fine mate
Had the rears fitted today but viewing them from the rear at the bottom of the wheel arch there seemed to be a 2 inch gap from tyre to wheel arch so the tyre was sticking out this much ? which i am sure could be against the law ??
      Engine bonnet release latch not working properly
      New member
      2016 M240 "lumpiness" at steady low speed
      645ci coolant
    5. 2
    • davecullen6 earned a badge
    • Sussex Kev earned a badge
    • Clunk 84 earned a badge
