Does Anybody Know This 2003 330Ci Clubsport (Estoril) ?
Morning Jon The main reason I moved away from run flats with the X5 E70 was tyre choice, with my E53 X5 I had plenty of practice. I learned that the recommended Star marked tyres were (a) not necessarily easy to get (often on back order) (b) They were also very premium priced (as you know) I started using Bridgestone and Hankook and found that they were as well matched in a staggered set as the Star marked tyres so no transmission damage. I brought the E70 to cut the miles going onto the other X5 and quickly moved it onto Hankook non run flats a set of 4 285x40x20 Front and 315x35x20 rear was just under £800. In my breakdown kit I have as said a small compressor a can of tyre weld (or similar) and a tyre plug set. I have used it a couple of times a friend of my wife has a Volvo V60 on run flats she ran over a screw one of the plugs fixed it and stayed fixed until she needed tyres. My son inlaw suffered pot hole damage to his 330e when visiting us, a can of Tyre weld got him from Sussex back to the West Midlands where they live. When he went to the tyre shop they said "shouldn't use that stuff mate we cant repair tyres that have it in" well with 2 splits in the inner side wall it was a new tyre anyway but at least he could drive 190 miles and not be stuck overnight waiting for somewhere to open. If there is a puddle I slow right down or go around if I can because in sunny Sussex it will be a Pot Hole I would go with a repair/limp kit like mine and fingers crossed the roads on the continent are in better nick than ours As an aside our son inlaw started a claim against the county council it took ages to get a resolution they wanted to know how many miles the tyre had covered ? then how old was it then said as it was a used item they couldn't offer full value !!!! An invitation to appear on Rogue Traders finally got through Dave -
Hi Jon Welcome to the Forum First is your car fitted with a Square wheel set (same size rims front and rear) or a Staggered wheel set (Wider rear wheels than the front) I suspect your car will have a staggered set probably 8j Front and 9.5j rear, so fitting a space saver wheel/tyre will mean there will be a different rolling radius on one wheel which can cause damage to the Transfer case and or diffs quite quickly if driven on for any distance (probably why your Dealer was vague) Even if your car has a square set up if the rolling radius of one tyre is different damage can occur. It isn't just BMW who suffer from this many 4x4 cars have the same issue. First you would need to check the Off Set to make sure the 19" wheel clears your Brake callipers and fits in the boot along with a Jack and wheel brace. Then if you are sure it is only a real emergency measure and not a solution that will allow a distance to be covered and aware of the risks why not. I have 2 x X5;s both run 20" staggered wheels and early in their lives I changed run flats for standard tyres (as generally they are easier to source and wider choice, care still needs to be taken that front and rear Rolling Radius are closely matched) and I keep a small compressor and Tyre goo in the car in case (BMW actually supply these as well). I have used it twice and happy to say not on my car but to help out others. Hope this helps not confuses Dave
