Annoying Judder On The E65
prestige interiors
Hi all need a bit of advice ...
The e65 7 series has a annoying judder it feels a bit like a misfire or petrol shortage ..
Some times pulling away from a roundabout it sort if holds back before pulling away and when your doing 30/40 mph the revs jump up and down like its struggling
Start with a good clean of the throttle-body mate. Get it off and scrub it with some diesel
Failing that, if it's a sensor fault it should be stored as a code so run an OBD reader on it. I have one so if your at the Milton Keynes meet....
Thanks Daz for your input someone else said it may be a sensor prob won't make the MK meet for one this weather has put me behind at work and the engine fault drive moderately light has come on a couple of times this week I want to get it sorted before I take it on a 300 mile round trip
Ok guys just an update in the judder ...
Although the air flow issue did solve the main judder once this was fixed it developed into a miss fire and engine fault light coming on with message saying
Excessive acceleration may damage catalyst.
The BMW reader showed that cylinder 7 coil pack was down so £87 later new one fitted and my faith in the V8 cruse ship was restored :-)
      650i crank no start
      Wireless charging?
      Just purchased 320d Touring
      Parking Break Failure
    5. 4
      650i crank no start
    • Astonred earned a badge
    • Retro_Alloy earned a badge
    • flateef earned a badge
    • John D Walters earned a badge
