Air Bag Light Again
tony pa
thanks for the help bypass unit probley not worth the bother was told to dissconect the plug under the seat give it a spurt of wd40 connect then reconect a few times dint work on mine but worth giving it a try thank you
  • 4 weeks later...
Check that the wires are not chaffed. This happens on RHD models due to different location of the wiring plug. If that is the case, repair and it will be ok. If not, get a new pretensioner from a breaker.
Gret the light reset and hey presto.
      Amplifier replacement.
    5. 3
    • Danny428F33 earned a badge
      Reacting Well
    • damiansteel earned a badge
    • Loulou earned a badge
